2008 ktm 200 exc
will my 6 foot 4 inches and 245 pounds bog down too much on a ktm 200 exc? they seem to be a lot cheaper and easier to find than its bigger brothers. thanks!!
If that's what you want just re spring / re valve the suspension to suit you
im probably going to sound stupid here but I have no mechanical knowledge and I don't know how to set the suspension for my size
you send it off they will set it and change the necessary parts
Bog down as in the motor not powerful enough?
I'd think it would be good enough.. They're pretty snappy... I'm at about 180, probably 200 with all my gear, and it rips pretty good for me.
Respring for your weight and you will be good to go. The engine will pull you just fine.
