Removing rust from nickle plated expansion chamber
So I just picked up a used FMF Gnarly for my CR after pancaking the brand new one I picked up 2 months ago.  This used one that I bought has some slight rusting on it near the beginning of the pipe where it attaches to the cylinder.  I would like to remove all the rust so the pipe looks nice again but I am not sure what to use.  After some googling I found a couple suggestions but I would like to hear from other people how they remove rust from their nickle plated pipes.
Thanks,
Scott
SOS pad or steel wool would probably do it
Diet come and aluminum foil.. Get's the job done.
Coke*
Navel Jelly
The FMF pipe is nickel plated so it is probably more like baked on mud. Wire brush usually does real good.
Thanks,
Scott
I have used WD-40 and a wire wheel on either a grinder or drill. The drill is kind of nice because it gives more control and let's you go slower. Takes only minutes and looks awesome.
You can hit it with some Mother's and a Terri cloth afterward :thumbsup:
Edited by Fattonz
