2010 yz250f doesnt want to run
rode the bike about a month ago and cut out and wouldnt start.so left it and kicked it last week and it started almost straight away and seemed to idle well. then i rode it and it would bog down low also if i shut off coming into a tight corner it would cut out. i have tryed adjusting the air fuel mixture screw and it would start fine but then cut out as soon as i touched the throttle. it then would not start until i adjusted the screw some more,then cut out when i tried to rev it, so now the bike wont run atall..
any ideas what it could be?
Bad spark plug
Clogged tank vent
Debris in carb
bought a new spark plug today, will clean carb and have a look at tank vent
cheers
