Need fork clamping dims for '09+ KYB forks
I was thinking of going to 20mm offset on the '08 unit which runs 22mm offset. I'm looking for the diameter of the newer KYB tubes where they clamp to see if its feasible to modify the '09+ clamps.
Thanks !
The stops on the frame are totally different I think (off the top of my head)
You shouldn't need a 20mm clamp on an 08 though. If its pushing the front, the rear is probably too soft.
Thought I'd give it a whirl - always looking to improve handling.
Ride Engineering has a set of 20mm, but they're a bit pricey to buy just to try. I figured if I could modify a stock set it would be an inexpensive experiment.
