stator problems 09 DRZ400SM
anyone had problems with the stator
a problem happened overnight
exhaust is good, tight
jetting is set just finejets are cleaned, clear
tank is flushed, clean
air filter is clean.
tested for leaks at carb boots. all good
plug burned great, replaced plug just to make sure
all is good BUT
it pops under wide open throttle at high rpms (don't have a tach so I don't know what rpm exactly)
is it the stator?????
Like the Shorai?? I'm impressed with the speed it turns the engine over, catches immediately now instead of a laborious crank.
What model bike?
What carb?
What jetting?
Could be the p/u coil, but time to diagnose it properly
(not like I did....rushing out to buy a stator that sits gathering dust)
1st question is has anything changed and what have you touched on the bike?
Then follow Mickeydee's advice
Edited by shuswap1
thanks for the replies
2009 DRZ400sm
not on the rev limiter
fmf power bomb core IV exhaust
jd jet kit
all jets are clean,float bowl ok, all carb concerns, jet size, needle position, vacuum etc all ok
k&n filter cleaned and oiled properly
