for all you studs
My boy snapped the axel holder stud off of a 1994 yz250. The four small studs on the lower front fork.   I see the studs listed for a WR250 and yz125 but not for the 250.
Are they pressed in, screwed in, or something else?
thank you.
They are bolt threaded. You use a closed end nut to twist them in make sure to use thread lock. You will have to use a die and tap kit to get the broken one out. Your best bet is order direct from your nearest Yamaha Dealer for replacement part.
That is what I had to do for a friends. I had checked Motorsports, bike bandit, and rocky-mountain under OEM parts and found no part number listed on schematic. It shows studs just no part number if I remember correctly.
Edited by TheDank
Thank you
wiggled, not torqued it lose.  Then just put a bolt in for now.
