2005-2007 CR250 subframe question
Part number for subframe in 50200-KSR-711 which supersedes 50200-KSR-710. Does anyone know what changed, or what the difference is?
There is a site that breaks down and explains Hondas part numbers, but I'm not sure where the link is at right now. Anyways the first set of numbers is the specific part number which is the same for both. That means that its the exact same piece. The next series of letters and then numbers again differentiate between let's say color options and then the manufacturer that they are getting that part from. So in this case I'm guessing the letters indicate that its the same color or style and the different numbers at the end mean they are now getting it from a different supplier. I may have that backwards, but that's the gist of it I do believe. So to answer your question its the exact same part, but I'm guessing they are simply getting it from a different supplier these days.
Thank you sir.  That was just the information that I needed.  I found a 710 on ebay and saved myself about $200 from a new 711.  Hopefully when the part arrives, It will be in good condition like advertised.
Edited by magpie5
02-07 cr250 and 02-07 cr125 subframes interchangenge
While the 125 & 250 subframes are interchangeable, note that there is a difference between the two.  That is the 250 subframe has an additional attach point on the right end for a silencer that the 125 does not have.  My 125 Q silencer uses the fender bolt for that attach point.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
