2004 RM 125 Help Please
Hey
I am working on my cousins 2004 RM 125. The bike has no bottom end at all. When you going to take off it just boggs. But once you fight to get the rpm's up it works really good.
This is what I done so far.
Compression test 140PSI
Adjust carb float.
main jet 380
pilot jet 37.5
Checked reeds look good.
Clean out pipe (stock)
repacked muffler (stock)
cleaned and oiled air filter
replaced left side crank seal.
There is no adjustment on the exhaust valve but I did check to make sure it moved freely. It quite a bit to push up the lever compared to my 2000 RM 250.
So if you guys have any idea on other stuff to check or what to do I would appreciate it.
Thanks
It is a little low on compression and you never mentioned where the clip is at on the needle "much more important than the pilot". I'm assuming the 2004 has the round slide carb where the jetting runs different than the newer models. And what's the gearing on the bike?
So I installed some new V-Force 3 reeds. The bike is work way better still need some fine tuning play with the jetting a bit but I think I got it. It pulling pretty hard through the gears and pulling wheelies pretty easy. So 140 psi is not bad compression  for a 2004 RM 125.
If I run into any more issues I will post.
Thanks everyone for the help and input  :ride:
