yamaha7442
YZ125 motor / GP Roadrace cylinder mod
Found a YZ125 motor that had
been used in a shifter kart, for
dirt cheap, and have a cylinder /
top end off of a GP roadrace bike.
Will take quite a bit of fabrication
and mods, build a custom pipe
...but the power gain should be
well worth it.
The GP bikes make 50 to 56+ hp,
but this motor will get the power
curve shifted for more low end.
Combustion inserts are available
from 12:1, up to 18.5:1.
58mm cyls are also available.
Edited by yamaha7442
  • Like 3
What kind of jug is that? It has an electronic PV setup must of had a different ignition system cdi etc gp road race bikes also go boom fast too.
A few comments. I race a crg shifter with a kart specific modified 99 cr125 to run in the "stock moto" class. First and foremost 125cc kart engines are ported to provide max power at anywhere from 12,500 rpm up to 14,000 rpms depending on the brand of engine. Kart engines do not make low or mid power. All kart engine builders even go as far as removing and plugging the exhaust valves for more peak hp. So imo you will be very dissapointed if you're thinking a road race built engine will work in a mx bike. I't wont.
Edited by Polar_Bus
  • Like 2
Aprilia
...their system can program when, how fast
the PV's open ...its awesome.
This cyl can also run Pneumatic, or even
hook it to the yamaha governor
How are you planning on using this motor? Off Road? If so, you will have a nearly impossible time trying to keep it on the powerband. Just my thoughts.
The cyl has a double blade PV, that works
great for broad mid.
Pipe design, ign, and exh port height
will determine the powerband
Haha
...no offense, but this isnt my first kick
at a modded motor.
Saying it wont work is like saying Yamaha
could never have built a 4 stroke mx bike.
How did they do it ? Didnt they use one cylinder
off of a GP bike ? Airflow is everything.
People laughed at Audi trying to run a diesel
at Lemans. Now Mazda has the Skyactiv diesel
They both had fuels made for the motors,
Mazda using chicken fat biodiesel.
You've most likely heard of Swedetech,
how much hp do their full race Honda's
make these days ?
Here's a dyno comparison of a couple
Kart KF 125 cc motors, and the orange
line is a direct drive set of cases with
the GP 125 cc cyl, no PV, and a basic
ign, running on VP 113, and a roadrace
pipe.
Obviously adapting this cyl to a YZ 125
bottom end will have some setbacks,
and power losses, but even if it
ended up with 40 to 45 hp, it would
be am improvement.
...just tryin to keep the 2 smoke world
goin' :)
Haha
at a modded motor.
Lets compare apples to apples,  2s and 4s are two completely different types of power, as is constant high rpm  road racing hp vs more varied rpm type MX hp requirements. So at this point you and I can agree to disagree, when your finished (and I hope you do follow through on your project it does sound interesting)  show me the dyno sheet for a MX based YZ 125cc making a broad midrange AND also capable of 50+ hp , and at that point I will be a believer.
Edited by Polar_Bus
  • Like 2
This one is an experimental
2 stroke "diesel", built with
scrap, outdated, and unusable /
un raceable parts, just to see if
it would work.
It starts, but need to work on the
howebrew fuel mixture ,
/ fuel delivery system to
keep it running.
It doesnt need an ignition,
or a tuned pipe, and C/R is about
24 to 30:1, depending on fuel
componenent percentages
1st failure.
The bolt pattern of the gp cyl and
the yz cyl are off a bit.
The original thought was to make some
alum studs to put in the yz cases, then
just drill new holes to accept the gp cyl.
But that would mean scrapping a set of
cases just for this test, plus the front right
stud was in the waterjacket ...no go.
Plan B was build an adapter plate,
but the surface grinder decided to
chunk the wheel right near the end
of the process, and tig welding the
damage warped the plate.
Start over with a new plate
Pipes are ready, cyl is ready,
...as soon as the plate is done (?)
will be able to fire it up.
cool part is, have heads available
that can run anywhere between
15cc to 7.5 cc head volume ( pump
gas, to VP's best ) and a carb setup
that can run meth
Even though its a similar design, the YZ-F is a far cry from GP bike specs, and like was stated earlier, an apples to oranges comparison. A GP engine used in an off road application is past rideable, which is why you have a completely different cylinder design in the first place. Not that it cant be done, I think you'd be farther ahead in the end bumping a stock ~35hp engine designed for MX up to 40-45hp instead of tuning a GP engine down to that level. Cool project nonetheless.
Have gotten into the 40 to 42 hp range
with Yz 125's, but that seems like as
far as it would go, and power is narrow / peaky.
Have seen others get more, though
The GP cyl on another bottom end has
a broad curve, but seems to sacrifice
bottom end due to the larger case volume,
...which does help the overrev in this
cyl set up.
1, or maybe 2 other benefits of putting
this top end on a yz, ...smaller case volume,
since the base of the cyl has been cut 5mm
to accept the 5mm plate, ...and can run
the pv off of the yz governor, instead of
pneumatic, or electronic pv control.
Dont mean to bring up 4 strokes
again, but look at basic comparisons
Some of the 4t mx bike builders
and engines are getting insane
numbers now.
Maybe look at it this way
350ci in a car, maybe 200 hp
350ci, well built, maybe 400 to 500hp
Nascar (roughly 350, 360 ci ?) 800 hp
Whats the difference, other than quality
of parts, rpm, lots of dyno work, and airflow
similar thing with 2 strokes,
garden equipment, not much hp (haha)
125cc stock dirtbike, 32 to 35, approx
125 gp, 50 + hp
So far, has'nt cost much other
than spare parts, and spare time,
...but wont learn anything unless
its tried
