03 CR250 & CR125 STATOR INTERCHANGEABLE?
No, they are not the same- the stator wiring harnesses are different. They are not plug-and-play with each other. The 250 has a single wiring connector coming out of the stator that plugs into the main body harness. The CR125 has 3 wiring connectors coming out of the stator that plug into the ignition components.
I dont know if the actual generator portion is the same- if it was you might be able to rewire it, but its probably not worth your time IMO.
2003 CR250 part number 31100-KZ3-L31
2003 CR125 part number 31100-KZ4-L31
