help with clutch lever in Acerbis handguard
Hey All,
I just got new Acerbis Rally Pro handguards, the old ones were bent/cracked from the bike going down so I got some new ones. The clutch lever is sticking out of the bottom, I did not get new clamps, I replaced the plastics only. I know the lever should be on the inside of the guards, is there an easy fix for this, is it ok if it sticks out of the bottom a little? Not sure if the clamps can get bent/moved? I did not try to adjust them. Tips and feedback would be appreciated.
loosen all the bolts up (lever) and see if you can get them to fit in.
did it used to fit in?
Yeah it used to fit with the blue handguards I had. Loosen the clamps/clutch lever?
loosen it all up.  if it fit before it can fit gain.
