USWE SPORTS ACTION HYDRO PACKS GIVEAWAYS!!! Read more... ×
Needing a new bottom end. Any reason I shouldn't go with this
This is the best price I've found so far.
I've got play in the crank bearings (can grab the flywheel and feel it)
So I'm pretty confident on what's wrong.
http://pages.ebay.com/link/?nav=item.view&id=200929201223&globalID=EBAY-US
I'm going to pull the motor out today and start to tear it down before I start spending money just to make sure.
I've never done a bottom end before so figured I'd ask some input before I spend money
Hotrods makes some good cranks second best to OEM stuff IMO. Just avoid Wiseco like the plague when it comes to bottom ends and you should be safe.
What's the problem with Wiseco bottom ends?
Here is one that was just pulled from a 2001 KX250. I am thinking the runout and clearance issue with the cases must have caused the stuffer to heat up to the point it started melting and disintegrated itself. On the same side as the missing stuffer it also had a missing thrust washer.  If anyone does buy a wiseco I would sure have it looked at by a good machinist before you install it.
can't say on the 2 stroke, but I have seen a few hot rods failures on 4 stroke. I only go OEM or Carillio rods stock pin and bearing
