Will a 1995 RM250 Tank fit a 1995 RM125?
I am looking for a oversized fuel tank and found the IMS 3.4 for the RM250.
Will it fit on the RM125?
I don't have 1st hand knowledge for you.  Later models swap across 125/250.  I am ONLY GUESSING that they would swap for the 95.  I would see if you can find the OEM part number for the stack tank for that year and see if they are the same on both bikes.  That would be a good enough source for verifying they would swap for me to then order the tank.
Don't quote me but I'm  pretty sure even if they are the same the part number will still be slightly different. Maybe just the last number.
https://www.thumpertalk.com/shop/oem.php
Hmm that may be a possibility.  Does IMS still list the tank somewhere and does it say it will work with either?
