96 rm250 with bad motor-$200
So I have an opportunity to buy a 96 rm250 for $200. Clean body not beat up and everything is there. Downfall is the entire motor needs rebuilt or a whole new motor period. All parts are there. What are your guy's thoughts?
Buy it, before someone else will.
Think $200 is real cheap.
Even if there are no extra parts it is cheap.
Good luck.
do it, 200 dollars is really cheap, where in iowa are you? i do alot of engine work on the side and would be happy to do it for you
Unless you are doing the rebuild yourself, don't do it!!! By the time you get the crank, piston, gaskets, and the cyl. replated you are going to have quite a bit into it. Pay someone to do it, and the price will be more than buying a good bike
I'd do it for $200.  But I do my own rebuilding.
