easiest way at carb
What have you guys found is the easiest/ quickest way to access your carb to swap out jets.  Are you able to leave it on the bike?  Bike is an 09 250.  thanks
you can twist it in the boots and pull the jets trough the drain plug but its not all that easy. Probably better off pulling the tank to gie you more room.
Buy a old air cooled one, screw the top off twist it and pull the bowl and have it done in 5 minutes. Or buy a modern one and spend 30 minutes jetting. Gotta love modern technology.
I pull the tank and then I can rotate the carb to access either the needle or jets.  I find it helps to remove the case guard around the front sprocket to give me just a little more room.  Also it helps if you pull your throttle cable towards the carb a little to provide extra slack, just make sure you put it back or it can open the slide when you turn your bars to the stop.
No need to remove anything. Just loosen boot clamps, and twist carb.
Edited by Fasz Kalap
Mine won't, might be something to do with the big tank. I have to pull my cable before I can rotate it. I have had mine apart more times than I can count.
