XR650L coil wire to plug boot connection question
Is is correct to assume that the OEM stock plug boot is a twist connection to the coil wire on a 94 XR650L and not a crimp on? The connectin was very weak on mine and came off with hardly a twist. If so, I assume you just strip bare a short section on the tip of the wire then insert as far as the wire will go int the boot and give it a couple of twists.
Did a search in this section on replacing spark plug boot and couldnt find a thread with that title.  My apologies for the newbie Q.... :ride:
