Silencer or jet?
Im in a bit confused about this, my bike is top notch (according to me) in the low end but it seems lacking on the top end pull. My concern is about the exhaust, it needs to be repacked, is this something that would affect the top end pull and or is this solely a main jet issue?
Try repacking the silencer 1st
...worn out packing causes
turbulance, and have seen it
lose 2 to 4 hp on the dyno
There are some woven fibreglass
sheets of packing that seem to last
quite a while longer. Rotax Max karts
use it, and 1 sheet of Rotax mat might
be enough to do 2 silencers
Maybe clean the inside of the tuned pipe
as well. Dirty pipes will run colder. as the
carbon buildup / oil acts as a shield between
the exhaust flame and the metal
Have heard of people using carb cleaner
to soak it out, ...or put a bunch of pennies
in and shake it, ...or bead blast it with
glass beads, or other soft media -
sandblasting it might be to harsh,
and take off a bunch of metal
How do you cleans pipe always wondered
I barbecue them if I think they are really clogged with carbon (!).  I've done this on several vintage bikes and it works just fine....Buy one of those large bags of charcoal and lay it out where it won't case a problem (grass fire!).  Dump the entire bag of charcoal, nestle the pipe in the charcoal so it contacts as much of the pipe as possible and light it up.  After a few hours, it should be cool enough to handle.  The heat burns & loosens the carbon but to break ALL of the coating loose, I have a speedo or tach cable that has a couple of inches of inner wire exposed and put the other end in a drill and ream it in and out.  It loosens it all!  Never has a pipe warp or anything bad happen but of course, they have to be cleaned and re-painted.
