SXF 350 STOCK STACK
SHOCK COMP
44.25X3
28.10
44.25X4
42.25X2
40.25
38-36-34-32-30-28-26-24 ALL.25
21.30CLAMP
REBOUND
38.25X2
36.25
34.25
20.30
FORK COMP
24.10X5
22.10X3
20.10X3
18.10X3
16.10X3
FORK MIDVALVE
ID6 8.30
20.10X3
18.10X2
16.10X2
14.10
10.20X2
18.40
REBOUND
D24.10X3
12.10
16.10
14.10
12.10
10.20
16.40
DAMN I FORGOT 14 year model
What float
0.25-0.28
Shock comp looks brutal ?
you also have the setting sx 250 2014 2 stroke
hi michele the sx 250 2t is a very hard bike!!! you can use my stack for starting point .
the problems are on the monoshock. jumps like a goat
Its most likely the rebound that makes it so crappy...
You need a revalve for sure.
Edited by Vietze
michele i mistake you must try my mod setup , there is a thread  WP FORK MOD STACK there is also the shock stack modified, the newer stock rebound sucks
SHOCK COMP
44.25X3
28.10
44.25X4
42.25X2
40.25
21.30CLAMP
REBOUND
38.25X2
36.25
34.25
20.30
FORK COMP
24.10X5
22.10X3
20.10X3
18.10X3
16.10X3
FORK MIDVALVE
ID6 8.30
20.10X3
18.10X2
16.10X2
14.10
10.20X2
18.40
REBOUND
D24.10X3
12.10
16.10
14.10
12.10
10.20
16.40
Last shim fork comp stack 6x16x0,1 ???
last shim fork basevalve is 16.10 x 3
Thanks !!!!!
Piston same as the previous year ??
yes wp recycle part from many year ...................
Thanks...
SHOCK COMP
44.25X3
28.10
44.25X4
42.25X2
40.25
21.30CLAMP
REBOUND
38.25X2
36.25
34.25
20.30
FORK COMP
24.10X5
22.10X3
20.10X3
18.10X3
16.10X3
FORK MIDVALVE
ID6 8.30
20.10X3
18.10X2
16.10X2
14.10
10.20X2
18.40
REBOUND
D24.10X3
12.10
16.10
14.10
12.10
10.20
16.40
too little shims shock reb stack
what did you think of the bikes suspension standard ?
