Add more HS shims instead of going for a bigger clamp
Hi guys, just wanted to ask your opinion on this!! i ride my TE300 in the track now and change the shock settings to suit!
only change i did was getting a 22mm clamp in there but its to harsh in the tracks i ride for my speed!! HS adj is all out with this
original setting was this below
44x.20 (5)
28x.10
44x.20
42x.20
40x.20
38x.20
36x.20
34x.20
32x.20
30x.20
28x.20
26x.20
20x.20
i add a face shim on rebound for a 7.2 spring
i was thinking of going to a 21mm clamp but dont have one yet so i thought to get some more in there like 27,29,31 to stiffen it up and go back to 20 clamp
i think is better use 20 clamp and add low speed
shall i use 5x.25 or more 0.20's
you dont think HS is needed for bottoming from jumps!
on woods you need  less low speed , use 44.20x7 for first test
this for mx!
te 300 for mx????ah sorry , i dont read mx use, i think was for woods , never seen here a husaberk on mx track.
for mx you can add more hs yes
the 11 TE has the last 2 stroke sx pds chassis and cc forks!
dont have money for a second bike now so i get to use the berg to practice at the track
hey mate,
this is the last SX 250 2stroke PDS mx stack. I'm not 100% sure but I think the husaberg has the "old" SX PDS frame?
So this would be a nice starting point for you. However, I did a TE 450 11 enduro to XC/MX conversion. I can send you the stacks too.
here it goes with the stock SX 250 2011:
Primary Comp 44 x 0.20 (8) 42 x 0.20 (2) 40 x 0.20 38 x 0.20 36 x 0.20 34 x 0.20 32 x 0.20 30 x 0.20 28 x 0.20 21 x 0.30
Primary Rebound 36 x 0.20(2) 26 x 0.15 34 x 0.20 32 x 0.20 30 x 0.20 28 x 0.25 20 x 0.30 21 x 1.00 spacer
Secondary Comp 40 x 0.25(2) 40 x 0.20(4) 38 x 0.20(2) 36 x 0.20(2) 24 x 0.30
Secondary Rebound 38 x 0.20 (2) 24 x 0.30
cadj 6 x 9.5 x 0.30 6 x 14 x 0.25 6 x 16 x 0.25 6 x 18 x 0.25 6 x 20 x 0.25(2) 6 x 22 x 0.25 6 x 18 x 0.10 6 x 22 x 0.10(2)
HSC = 1.5 LSC = 15 Reb = 22
Since this forum doesnt want us to share stack easily I can send them to you per mail too if you want.
Vietze,
The above shock stack is very similar to the stock ktm exc 07 stack I found.
I am now curious, TT does not want us to share stack information?
Vietze,
I'm talking about the crappy board software that makes stack lists very hard to read ;)
No problem in America, maybe is the German engineering over there!   :goofy:
no
hey mate,
Primary Comp
44 x 0.20 (8)
42 x 0.20 (2)
40 x 0.20
38 x 0.20
36 x 0.20
34 x 0.20
32 x 0.20
30 x 0.20
28 x 0.20
21 x 0.30
Primary Rebound
36 x 0.20(2)
26 x 0.15
34 x 0.20
32 x 0.20
30 x 0.20
28 x 0.25
20 x 0.30
21 x 1.00 spacer
Secondary Comp
40 x 0.25(2)
40 x 0.20(4)
38 x 0.20(2)
36 x 0.20(2)
24 x 0.30
Secondary Rebound
38 x 0.20 (2)
24 x 0.30
cadj
6 x 9.5 x 0.30
6 x 14 x 0.25
6 x 16 x 0.25
6 x 18 x 0.25
6 x 20 x 0.25(2)
6 x 22 x 0.25
6 x 18 x 0.10
6 x 22 x 0.10(2)
HSC = 1.5
LSC = 15
Reb = 22
interesting stack....no crossover....i will give it a try when am back in the shock! at the moment i run 5x44 .20with a 28 crossover and the reast stock with a 22 clamp....i will test it tomorow! Edited by wblake
