drz400 jetting help
got a 01 drz400S that i installed some parts
hot cams stage 2
39mm fcr carb MX style the TT kit
3X3 airbox modd
MRD SSW exhaust with quiet insert
MCCT
im looking for a base line jetting
im at 200FT elevation
45 pilot
Fuel screw set for the best idle with a hot engine
EMN needle, clip 3
158 main jet (possibly 155, test to see)
45 pilot
EMN needle, clip 3
Emn needle?
Does that come in the Thumper kit?
Yes. Installed in the carb is probably a EMR and you should of also gotten a EMN.
Bought it used good clean carb
How do you tell the difference ?
Will it say it on the needle ?
Yes, it is stamped on the needle.
How do you know it really is the TT kit carb?
Bought it on eBay
Was advertised as the kit
Came with some TT paper
Not sure where's it now
Intake boot
All the jets matched
Just didn't check the needle before I installed it
