2000 YZ250 died when riding now wont start
Alright guys I need some help on this.  While riding down a dirt road the bike died, I pulled the clutch in and coasted to a stop.  Tried to kick it over again, no go, changed plug still nothing.  Got it home and started into it but can't get it to fire.  So far I've:
disconnected the kill switch
checked compression (a little low, see below)
changed plug(again)
pulled the flywheel cover(everything looks correct, but i dont have a flywheel puller)
grounded plug to head(get blue spark)
cleaned the carb(looked pretty clean actually, jetting below)
Reeds look new
piston and clyinder look fine from intake and exhaust ports
And of course I had just filled the tank full. 32:1 yamalube R & 92 oct.
Compression: 160
Needle:  N3CW 3rd clip
Pilot: 50
Main: 180
Power: 55
Any and all ideas welcome, thanks in advance
Edited by Carcinogen
changed plug(again)
Reeds look new
Compression: 180ish (going to go check again to make sure WOT)
Pilot: 50
Main: 180
Power: 55
Hey man, so obviously, it hasnt seized, which is good. Okay so you have checked everything for spark. We know it needs three things to fire up. Compression/spark/fuel. You have compression and spark. Take apart the carb. Give it a good clean. Obviously check for clogged lines. Also check that your gas tank has a little tube on the cap. It has to be a fuel flow problem!
I completely skipped over that you cleaned the carb. My bad mate:/ How is the ring on the piston? i had this problem once where everything checked out, but the ring welded itself to the piston..
Spray some starting fluid in and then kick it over. That is the only piece of the puzzle that you havnt verified while kicking over. If it fires then you know you have a fuel supply issue to the carb.
Try a new plug? Could have fouled it
Could be a sheared FW key. Do you get any type of abrupt backfire ? Tell tale sign the key sheared and the FW is out of time.
I'm trying to avoid tearing into the engine right now if possible, dont have the money for a rebuild but they seemed fine through the exhaust port.  Is there an easy way to check?
I dont have any starting fluid, I'll have to get some and try that.
I dont think its the woodruff key, flywheel mark is still TDC when the piston is.
The exhaust port doesn't really cut it man. If you want peace of mind, you're going to have to open her up!
You didnt mention a new plug, just wanted to make sure it wasnt over looked :)
Have you pulled your fuel line and made sure the petcock is flowing good?
Yeah, petcock checks out ok.  Drained a full tank back into a gas can.  I do need new fuel line though , its old and stiff.
2 strokes need fuel, compression and ignition. You're missing one of these elements. You should at least be getting an exhaust fart or something.... i'm at a loss with this one.
When it died traveling down the road, what did it do? I'm still thinking it's in need of a new piston & rings. Check the compression again.
Just cut out as I was getting off the throttle.  And yes I'm sure it needs a top end, the power just wasn't there.
Oh yeah, checked the compression again last night and got about the same(but I dont have another gauge to compare against...) :(
Yeah man, me too.  It just kicks over without a sputter, which leads me to think its not getting fuel(or enough fuel).  I need to try the starter fluid suggestion.  What about squirting some gas into the plug hole and putting the plug back in, would that work?
No, if you do the fuel doesn't atomize with air correctly. Just yank the air filter, and give a good blast of starting fluid down the intake boot, and kick, you should get the engine to fire after like 3-4 kicks. Simple and conclusive test. I do it all the time to "isolate" fuel or ignition issues.
It doesn't want to start with starter fluid and it doesn't want to compression start either.  When I try to compression start it, it just locks up the rear tire.
Pulled the plug again and verified spark. I have not double checked the kill switch since the first day I tore it apart, but I figured it wouldn't spark to the head if the kill switch was bad anyway.
