clutch lever vibrations
Anyone else have this annoying issue? Guess I'll try and shim out the bit of freeplay with a washer or something tomorrow. What have you guy's that may have run into this done to remedy?
Let it vibrate like that for a year. It stops, eventually.
I Just deal with it mine vibrates on the hand gaurds. Tried to file a bit off the ball end to quiet it down some
I keep one finger on the clutch as a force of habit from trail riding... otherwise it just bounces around, live with it.
I tried shimming mine with section margarine lid plastic but it made the leaver tight.
I also put strong elastic band on the perch to ensure the lever is pulled in tightly but this made the clutch heavier to pull.
Then I nearly blow my hearing out on a high speed freeway run so now use ear plugs, I have no idea if the noise has gone or I just don't hear it anymore.
I would recommend ear plugs, you can still hear everything just fine.
I also now find the engine/exhaust noise less draining throughout a long days riding.
tighten the bolt ?
too tight = stiff lever
too loose = rattle
tighten the bolt ?
too loose = rattle
bolt is tight
Maybe try using a small bit of thicker waterproof grease or cut up a bit of shim-stock? I'm usually too busy hanging on for dear life to notice a rattle like that!
Edited by shuswap1
