freezing bearings and heating case problem
i recently tried to install bearings in my case without a press and one of the bearings went in a little crooked and is stuck now... i know im an idiot. can the bearing still be pressed in or did i really screw up??? any help is great thanks
u can try a torch on the case  and dry ice  on the bearing if your afraid to crack it with a press
I have blown sleeve installs and was able to fix them   u might not even need the cold side of the equation just the heat
ok thanks, gonna take the case to a shop and see if they can press it in the rest of the way
