Yamaha 04 YFZ 450 Starting issues
Ok i have this starting issues with my  04 yfz 450 like many others have. i have a high compression piston and its jetted with a hmf pipe. I have replaced the battery twice with higher cranking batterys, replaced the starter, had the valves shimmed, had the carb rebuilt, and The spark plug is new and gives good spark. I also run the quad with my headlights on whenever i bump start it. The issue im having is whenever i completely charge it up and take it out it will fire right up on the first click of the starter but if i shut it off it will not start up again without bump starting it. It sounds like there isn't enough juice pushing the motor over and sounds like the battery is dying but if i put it on the quick charger it says i have a high percentage left on my battery.
I was thinking stator, cdi box, or a relay please help its killing my wallet and motivation lol
