Tinny rattle/vibration from front of engine
2005 TT-R 230. Wondering if anyone else has had this issue, or know what is causing the noise? Valves are adjusted properly. Get it at higher RPM. Bike runs fine, just loud and annoying! Thanks for any info!
Same here, '03 TTR 225. Believe it's something to do with suspension? Not in the engine, everything's great there. It really starts happening when I gun it and get the RPMs up. I believe I pick up the front wheel a bit and something clicks in the front suspension because the bike also starts bouncing and vibrating fast. Need to do more research and also film it with a GoPro slow motion and check the footage.
