450 rekluse clutch on cr 250?
Hey guys, I have a 99 cr 250 and I found a rekluse clutch off of a crf 450 that is almost brand new only 2 rides on it and he is selling it pretty cheap, will it fit on my cr 250?
Thank you guys
Go to Rekluse's website and match the part numbers.....
It will need a clutch cover gasket, throw out spacer, and spring.
All part numbers will be listed on the website.
The guy I bought my 05 450r from had swapped a Rekluse back and forth from it to a 96 CR250 so I would assume that if your clutch is off of an 02-08 450, it will work.
thanks for the replies, the guy sent me a picture of it and its not a rekluse, its a revloc. Idk much about the revloc , are they any good? Im thinking about just getting the rekluse exp?
i bought my buddys 05 450 rekluse and use it in my 02 cr250. works phenomenal now that im getting used to it, and i scored it for $200! win win.
Was it a direct fit or did you have to get some different parts?
I have a rekluse exp 2.0 in my 03 250. Takes some getting used to. But seems to be an improvement.
You might have to gap your clutch cover using thick gasket material.
direct fit, all i did was remove some plates. replaced my disks with all steel while i was at it. i have a pro circuit cover on there and it's been fine
Okay, thank you guys for all thr information! I appreciate it
