Vac pump
How much vacuum are you putting on when bleeding the shock, without problems from pulling air past the seal head. I have only started vacing my Japanese shocks and find it easier to do by hand. Wp no problems.
How many psi are you using?
-15 psi the or a bit more vac...but i try stopping as soon as the bumber touches the cap!!
sometimes the KYB i did only couple of cycles and was air free!! :excuseme:  with no problems i know off!!
on vac you must use -1 bar but on many sealhead air is sucked in .
I've sorted it thanks .
So what was the outcome/conclusion?
More vacuum
