cr 125 pwk question
I was thinking about buying a 36mm or 38mm pwk for my 2005 cr 125. I know for one that came of a yz 250 you need a throttle cable from a yz250 or cr250 (i think) but i found a 36mm off a kx 125 and was wondering if i would need a different throttle cable or something else to get it to fit right. Any help would be nice and if you know anything else you need for different bikes
if you have a problem with the cable it is the internal length of the wire.  not the external. The slide will not bottom out if you have a problem with the length.
get one from a 2000 cr250 if you need the longer internal cable.
