2007 KTM 450 EXC revalve complete- I finally have something here
For the past few months I have been tinkering with the suspension on my  '07 450 EXC.  Here is what I ride and some bio:
175 lbs street clothing, ride both enduro, roots, rocks, dirt roads, street dual sport, light motocross both hard and soft, trails, singletrack.    These stacks are very nice for my senior C/B pace.  The bike is predictable and handles well.  I am still debating over the 28x.20 in the primary rebound, and maybe adding one face shim on the fork BV.
Changes I made to the suspension:
Front fork
Stock .44 springs 5mm preload,  flush with cap
Oil:  50/50 mix Maxima 5wt blue bottle fork oil and AW 32 hydraulic oil = 22Cst viscosity, 120mm from top.
SKF seals and wipers
Midvalve shoulder trimmed .028" on my lathe to reduce the float
Base valve:                  Mid:                Rebound:
2 24x.1                        24x.15              3 Delta x.1
14x.1                           22x.1                 12x.1
3  24x.1                        20x.1                  20
22                                 18                       18
20                             stock spring           16
18                               1.05 float               14
16                                                              12
14                                                            2  9x.3
11                                                             16x.25
8x.30
12x.1
18x.25
Shock:
Stock 8.0 spring,  5mm preload,  40/120 sag numbers
RT bladder conversion kit, 150 psi charge
Maxima 3wt shock oil
stock internal pistons
Primary compression:          Secondary compression:
44x.20 (4)                               40x.20
42x.20 (2)                                38
40x.2                                        36
38                                             34
36                                             32
34                                              28
32                                              24
30                                              20x.30
28
26
20x.30
Primary rebound:        Secondary rebound:
36x.20 (3)                       36x.20
28x.20                              34
34x.20                              32
32                                     30
30                                     20x.30
28
26
24
20x.30
Edited by Bailey28
Where are you running your clickers at?  If you run at a B pace the BV looks a little soft.  On the rear have you tried running a progressive spring?
