Rim size compatability?
I have a 19 inch rear wheel off a kx125, and the rear wheel on my drz400 is dented on one spot. Will the kx125 wheel fit, hub and all? Or will things like disc brake sprocket etc not fit?
Also, I am looking at warp9 rims and they look pretty good. Will a 18 inch rim fit on the kx125 hub?
You would need to get a 18" rim that would fit your hub.  I doubt that the KX hub will work without modification though.
If you are interested, most KTM rear hubs bolt up with no changes.  Something like anything 125 or larger from somewhere around 1994 - 2007.  I have a 300 EXC rim on the back of my bike now.
Well, the KTM rims bolt up, but I did machine a little off of one wheel spacer and added a shim behind the sprocket to make the fit almost the same.
They are a snug fit.
