oil coming off air filter?
i been using this filter for 36,000 miles now, ive cleaned it every 10,000 miles, it never really gets too dirty anyhow. i decided to clean it the other day a few thousand miles early.. it all went good, bike had more pep to it..
i was outside just overlooking the bike, and noticed all this wet looking plastic
so i checked out my filter and it seems the oil is coming off.
hard to see in the pic but its all wet and oily in the airbox
i clean with pj1 air filter cleaner. and oil with k&n air filter oil (black spray paint bottle)
this is the same exact routine i used for the other times i cleaned it.
should i be using a different air filter oil?
i was reading that the K&n stuff is for gauze filters.. NOT foam filters like my twin air filter
i have not noticed the oil come off the filter before, maybe i just excessively oversprayed it this time, the filter looks 80% new pretty damn nice if you ask me for how many miles are on it
Edited by 707LAKE
Is it not oil coming from the oil vapour separator tank?
I know it spews into the intake boot, and if you're in a lengthy wheelie and maybe slightly overfilled on oil, it could run back through the filter?
Edited by Nellisvan
yes that makes sense..
the oil i seen was reddish & smelt like air filter oil though
Edited by 707LAKE
I get sticky nasty oil dripping off of my filter.  Makes a mess on my swingarm, and apparently my dads garage floor.  Never leaked in my garage though.  Figures... LOL  I figure I just didn't wring it out enough last time.
You're using the wrong oil (K&N gauze filter oil) and you should be using a foam filter oil (pretty much all other air filter oils, PJ1, No Toil, Twin Air, Motorex, Bel-Ray, etc....).  Also you're probably over-oiling the filter too...
You need foam filter oil
I get that if I over do the re-oiling.
I've since got a bottle with a small nozzle on and use that to apply the oil to the filter, since doing so I use less oil and get better coverage = no drips out the air box drain anymore.
i just went and baught some uni foam air filter oil..will re-clean and oil later
