2002 kx250 kayaba fork rebuild info required !
Hi,
I went to reseal my forks tonight, and made a mistake. I loosened the valve on the bottom of the forks. Now I can't get the valve to tighten, or wined out all the way... How do I either remove the valve , or get it to tighten up????
often it works when you compress the fork (with springs in) while removing or tighten the base valve.
if not, you need an air Impact wrench or a cartridge holder tool
