yz125 piston pics
Looks wore out.  Measure the bore to make sure it is within spec and change those pistons more often.
You heard a knocking sound? How is the rod and crank? Most of the time knocking comes from the bottom on a 2t.
The rod and crank look great
Looks quite lean how do you mix? That apart the piston looks overdue.
I mix 32:1
The wear from the bridge on the exhaust side of the piston usually starts showing up when piston to bore clearances get excessive.
