1987 cr250 idle issues
My 1987 cr250 idles good when it's cold but when it warms up it idle high and low.
I cleaned the carberator really good and even tried another one still having the same result.
I haven't tried a new slide. The current one has minor wear marks but not too bad.
My fuel to oil ratios is 31-1, and I have tried everything with the air and idle adjustment on the choke and still get the same result.
Does anyone have any advice?
Thank you
does it do the same thing with the air screw all the way in?  kinda sounds like an air leak but it should do it when its cold weird
