Reducing engine braking
Anyone know if an R cam reduces the engine braking of the X. I find my X has heaps of engine braking and is prone to flaming out at lower rpm over technical ground. I'm new to Honda and the X, I come from a Motocross Yamaha background. A Yz450 has heaps less engine braking and not prone to flaming out at all.
Cheers
Marty
R cam may help,  Setting the idle up helps, as does being a gear higher.
You need to properly uncork and rejet first and foremost.
Then it will run free and cool and not flame out.
Read the pinned posts at the top of this forum.
To get less engine braking, just shift up.
