drz 400 e carburetor instructions
hi i have a drz 400 e and i took off the carb and cant seem to find information on which tubes connect to if you have and information or experience on this please help
That carb has 1 vacuum hose for the coast enrichener (CE) and 1 fuel hose.  The vacuum hose for the CE connects to a nipple on the cylinder head.  The CE is often removed from the carb.  If so, the nipple on the head is removed and the hole plugged with a 8mm bolt.  The fuel hose connects between the gas tank fuel petcock and the carb fuel inlet nipple.  All the other hoses on the carb are vents and drains.  The hoses just hang down by the swing arm.
