Cam shaft
My cam chain is way to tight and won't go back in place right any ideas?
The cam won't go back into place?
Let all the tension off the tensioner and then remove it.  Then slide the left (gear side) cam bearing towards the gear and drop the cam into the head to install the chain.
Set timing.
Make sure tension is off tensioner and install, the release the plunger.
Edited by dirtydrew
