09 kx450f top end
Ive read all the post about the updated piston from the 2010 and 2011 to put in the 09 kx450f. My question is I found a compelte oem kit for the 2010-11 kx450f. Do all the parts fit the 09 and these are the updated parts? Below is the list of part numbers out of the kit.
(1) 13001-0128 Piston
(1) 13008-0018 Ring Set
(1) 13002-0028 Piston Pin
(2) 92036-008 Circlips
(1) 11061-0353 Base Gasket
(1) 11004-0088 Head Gasket
(1) CPR8EB-9 SPARKPLUG
I did this exact thing, here is my list from the order.
OEM_KAWASAKI_TPL.jpgGASKET,CYLINDER BASE
11061-0353
Fits: 2009 Kawasaki KX450F
1 $8.68 $8.68 OEM_KAWASAKI_TPL.jpgGASKET-HEAD
11004-0088
1 $26.04 $26.04 OEM_KAWASAKI_TPL.jpgGASKET,38.9X46.4X3.0
11061-0082
Fits: 2010 Kawasaki KX450F
1 $4.62 $4.62 OEM_KAWASAKI_TPL.jpgPIN,10.1X12X14
92043-4009
2 $3.48 $6.96 OEM_KAWASAKI_TPL.jpgPIN-PISTON
13002-0028
1 $19.14 $19.14 OEM_KAWASAKI_TPL.jpgPISTON-ENGINE
13001-0128
1 $84.19 $84.19 OEM_KAWASAKI_TPL.jpgRING-SET-PISTON
13008-0018
1 $32.09 $32.09 OEM_KAWASAKI_TPL.jpgRING-SNAP,PISTON PIN
92036-008
Yes sir! I did all 2010 top end parts with 2009 gaskets. You may also want to order the # 11061-0351 as I didn't and just recently had to. When you take off the head cover you may get a little oil leaking out of the cover gasket. This is the one thing I didn't replace when I did the top end, I just bought one a few weeks ago, plan on putting it in soon so that should stop my issue. A friend is a dealer mechanic who does a lot of work for me and said it is common when you reuse that gasket because of the glue that comes on it from factory.
