halp - where do I adjust 2008 DRZ400SM chain?
My chain seems really loose, and I'd like to tighten it a little.  On my last bike there was a nut on the end of the swingarm that would push the axle in or out.  Easy to adjust....
...but it looks like the only way to do that on this bike is from the side (just behind the weld).  Is this true?  Seems a bit odd.  I only have socket wrenches, so am I out-of-luck?
Yes you're out of luck if you only have sockets, if you have the OEM tool kit the necessary tools should be in there.
Otherwise you will need to buy a couple of open end spanners.
I would suggest getting the correct tools, doing a complete removal of the adjuster bolts and put either anti seize or some water proof grease on the threads and reassemble..
Cool, thanks for the reply.  I think I have the OEM tools buried somewhere in my garage, so I guess this gives me an excuse to do some cleaning.
Of course you need open ended spanners....
12mm for the lock nut and 10mm for the adjuster...
Make sure you have adjuster marks the same on both sides after adjustment, and pick the rotation tight spot of the chain to do you adjusting on....
After you think you done sit on the bike (with a friend if available :) ) and compress the rear suspension to make sure it's not too tight...
Edited by Craigo 485sm
Practically every MX bike and sport bike made adjusts the chain that way... Having the axle blocks inside the swingarm on adjuster bolts (your last bike) has become a bit of a rarity in the last 15 or so years, and even Nautilus cams (DRZ400S style) are few and far between.
The SM chain adjustment method is more precise for chain adjustment .....
With the cam style adjusters quite often the chain can be too loose and when you go to the next click it will be too tight..
Absolutely .. This is a major issue with this type of adjustment
Yeah , if you get enough weight on the bike so that the countershaft , swingarm pivot and axle are in line . You only need 1/2' chain slack at this point .
The chain will be at its tightest when the 3 points are in line .
This is a double bonus for you. You get to go TOOL SHOPPING and work on your own bike.
After further examination, WHERE IS YOUR LOWER CHAIN GUIDE? Are both chain rollers in there? This could be why your chain is hanging so much.
got the chain adjusted.... not as cumbersome as I thought it would be.
previous owner removed it (don't ask me why).... I still have it sitting in the "box of parts" which I found the tools in.
I see one chain roller (behind the side-stand)... where would the other one be?
Edited by joey v
The other one is above, near the regulator/rectifier but would not affect chain tension. Looks like your OK. I would put the rear guide back on ASAP though. :ride:
Above the swingarm for the top run of the chain, stops the chain from hitting the air box when the suspension compresses..
Chain guide is not needed on the road, it is there to stop the chain from getting knocked off the rear sprocket from rocks and sticks when riding off road.
But it does have the added advantage of keeping your foot out of the rear sprocket in the event of a get off,ask Daryl Beattie about that.
From Wiki,
Beattie had a lackluster season in 1994 on a Team Roberts Marlboro Yamaha. During the 1994 season at the French Le Mans circuit, he crashed and lost all the toes from one foot after his foot was caught between the chain and rear sprocket.
Chain guides are there for a reason.....reinstall guides ASAP....... :bonk:
I have should have added that at full extension and compresion of the suspension the chain will be very loose and can derail itself without the chain guide in place. :naughty:
Edited by Black_DRZ
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
