Cr 250 top shock bearing
Also for a crf 450 and crf 250
So i was sick of my top shock bearing/bush
Turning to dust and even when new having a ton of play in it
And after taking measurements fit soon came apparent you can replac it woth a standard skateboard whee bearing..
ImageUploadedByThumper Talk1382266864.301352.jpgImageUploadedByThumper Talk1382266898.053786.jpgImageUploadedByThumper Talk1382266917.584153.jpg
So i put two beari gs i and have had to make a
Bush similar to a penny washer on one side to get the width spacing good but for a fraction of the price i have taken a ton of play out of this and it genuinely feels better.
Any comments welcome
Two things I wonder about:
1) Was the original bearing a normal needle bearing, or a spherical bearing that allows a large range of angular movement?
2) Will the substitute bearing take the load put on it over time?
Edited by YZEtc
You will ruin your shock! The upper bearing is angular for a reason. The frame, swingarm, shock shaft flex bend under load. The angular bearing is there to keep the shock out of bind. Bad idea take it out.
How many mm do you think the swingarm is going to bend.....
Take that through the pull rods..
And then that will run through the
Link...
There would be so so little
Movement less then 1 degree which
Wouldnt bother the new bearings
(Two running in series)
And how much flex do you think
Is in my frame???? Im not robbie maddison.
The original was a spherical bearing that could move through about ten-15
Degrees which is way over the top
And the new bearings are a skateboard bearing...
Will never rotate over 1 rpm
And think of the hits a solid skateboard wheel sends through to its. Metal trucks
My shock will be fine...
