Rm 250 rev limit issues
So I took my rm250 out for a ride over the weekend and she went good for its of the day then I went I climb up a fire break and I noticed that it had lost all is power would just both down to nothin. So I went out in to a flat paddock for a burn to try work out wat was going on and I would get to about quater throttle and it wouldn't jump in life in the power band area instead just rev limit like no tomorrow any ideas anyone
Edited by BarnettN
New Zealand and where just comming in to summer me a and a mate pulled her apart and look at the reeds, power valve, changed plug and shortened the lead just case it was cracked, new fuel, pull the carby apart and cleaned her,new air filter pulled the fly wheel cover off for a look. Every thing seem good she starts and ldels like a dream but as soon as its under load no ones home as far as power goes
Does it smoke at all? White smoke means that its to lean and you should raise the needle and dark smoke means to rich and you should drop the needle. What colour was the spark plug?
Nar she smokes f##k all ae run it on 40:1 with 96 the plug look good wasn't super oily or anything ae the one that was in there wasn't the old but we put a brandy newy in just in case but still no better
My mate that looked at it with me used to be a bike mechanic and he reackoned that it still felt pretty good ae as far as kicking it over went
You said you took the powervalve apart. Just yesterday I decided to play with my adjustment a bit. There is a preload adjustment that will give you more top or bottom end power. Is it possible that that came loose and all you have is bottom end?
Yea that could be possible didn't check or try it coz u had a couple of crack at getting up the fire break and even though it was bogging down and not that 2 stroke rev it balls off power I'm use to it did keep going and climbing till I reared it over it was very torquey and tractor like
If I have this right, turn the adjustment counterclockwise for more top end. Not too much because on mine it moved it so high that I couldn't, hit it without having a blown motor scare. Start with 1 turn tops. If that doesn't work change it back and try a hotter plug. Ie if you are running br9's move to br8's. because my bike won't hit the power and unless its hot.
Not to discredit ya plug idea but it's always had more than enough grunt for wat I'm doing up until just now with the plug s in it. But I'll deffently have a play with that adjuster.
That adjuster makes a huge difference. If you turn it counterclockwise it will sound pingy on startup with more top end and if you turn it clockwise it will sound real smooth on startup with more bottom end. I typically stop turning clockwise when the spring will turn the adjuster on its own. It's a real easy adjustment that I change everytime I got from pit to woods or vise versa.
I hope that's wat it is some people I've talked to reckon it could be a electial fault like the stator or coil starting fail and casusing a brake down in spark under load any thorts on that side of things
Hahaha I don't like the look of those dollar signs. But thanks for the help I'll try play with that adjustment tonight
