Gearing help
I am running a 12 tooth on the transmission and a 50 tooth on the rear wheel on a 1.1 mile track it screams in 3rd gear but lugs in 4th it's a suzuki 250 2 stroke I am not sure if I need to go up or down in sprocket teeth any suggestions would be great
Do you want more or less power?
I would like to be able to run in 4th and not lug down
if it lugs w/ gearing that low then I think there is a problem, maybe top end time?
I agree
K it's running a Wisco ultra lite piston so maybe time for some rings and a new gasket set then is that all that needs replacing or is there more than that?
That's probably all
what year RM is it?  usually 3rd & 4th are pretty close together. Whats' the plug colour like?
Personally I'd stick a 13 on the front & try riding it, look at the jetting and do a compression check.
It's a 1992 rm250 2stroke I am running 125 psi on the compression gauge is that good or bad?
Let me correct that the compression test was 152 psi and held for a while
152 psi is really good I usually rebuild at 120. Did you hold the throttle wide open when you kicked?
Yep sure did
What color is your spark plug?
It's a little dark but not to bad
