Checking and changing oil.
How do you check the oil in a 09. I unscrewed the nut thing and couldn't really see any oil. I've only done about 2 hours on it and got it from a team moto so fluids should be ok. Just wondering. I put a bit in. Can you over fill? What are the consequences of this? I'm new.
Just measure when you do your change, I am accurate every time.  First time I never used that stupid check hole I rounded the allan head out, worthless
if no oil comes out of the check hole, its because your engine is low on oil. fill up till oil flows from check hole. suzuki´s drink a fair amount of oil, (at least mine do) so check between oil changes.
