Help!
This is going to seem dumb but I can't get my axle bolt back in. I've loosened the 4 bolts that clamp and the axle bolt is greased. Is this a common problem? Do I need to pry the clamp apart more? ImageUploadedByThumper Talk1382378810.358567.jpg
hey, man, what part of Idaho?  Heading up there this weekend.
This is going to seem dumb but I can't get my axle bolt back in. I've loosened the 4 bolts that clamp and the axle bolt is greased. Is this a common problem? Do I need to pry the clamp apart more? attachicon.gifImageUploadedByThumper Talk1382378810.358567.jpg
If that large end of your axle does not rotate freely in the fork lug, you will get binding in the forks.
Clean out the corrision, grease it, wire wheel it, what ever it needs so it is not stuck when you clamp down the lug bolts.
Otherwise, the right fork leg will not be in alignment with the left one.
I live in Boise Idaho
