Keihin PWK Carb Talk
Im having a very hard time jetting the pwk carb DUAL vent; its hitting the powerband VERY sudden and not smoothly;
Whats the deal with the QUAD vent PWK? is there a main difference and is it worth $250 for a new QUAD vent PWK carb over the DUAL vent?
What bike? What jetting? What needle? What slide? Stock bike? Modified?
the quad vent is meant to prevent bogging after jumps, it has nothing to do with how the bike comes into the powerband. if youre not bogging after jumps now, then no, its not worth $250.
2001 cr250
vforce 3 reed
fatty w/ turbine core silencer
pwk DUAL vent
I havent jumped it yet to see but i guess that there is no performance differnces between the 2 other than the bogging?
Edited by JB-250
What are your current jets and what temp/elevation? Also what size pwk is it?
2001 cr250
vforce 3 reed
pwk DUAL vent
there may be some performance differences, i dont know, i highly doubt it, but, like i said, the 2 extra vents are only for 1 purpose and thats to prevent bogging from the fuel plugging the vents after jumps.
Would i only notice the bogging after the "big" jumps?
Im at around 800 elevation with temps varying from 65-80; not sure on current jets but i have tried with slide # 6 and 7 which i cant tell which is better in what areas though; will report back with jets
size is just standard 38 i beleive as i cant fit a 39 can i?
use this to start.
45pj
a715 needle (stock 00 needle) on clip 2 or 1370dka or 1368dka (99 cr250) needle on 2-3
172-175 main
you need to verify your PV is working properly and isnt stuck open.
Edited by mynewcr250
Powervalve being stuck open is what i was 1st anticipating and i wanted to check it tomorrow
I will try what you said as well tomorrow; thank you
