noise from right side of engine?
When bike is on side stand no noise is heard. When stood up straight rotational noise is present.  6200mi on bike. oil change performed every 2k or beginning or season.  Have been practicing wheelies. Bike is an 05 drz-400sm. Thanks in advance for your help.
Same thing here, he says :
"makes this noise as it is tilted up off the kickstand. Anybody know what this is?"
http://www.youtube.com/watch?v=vgudh5ZLZ6U
Is that your noise ?
Aftermarket pipe rubbing the shock spring? That's my guess as I had the same problem.
cam chain adjustment?
Do ALL the loctite fixes .. As a precaution
michaelks,  sounds like video not quite as bad yet. have not done loctite fixes yet will be checking soon.
Have seen other posts of noise no diagnosis yet?
i wonder if it's the timing chain cog sliding back and forth on it's shaft ... about to slip off and grenade the engine ? (loose nut, needs loctited ?)
Thats a normal noise?! Mine makes this noise even when i first started when i rebuild the whole motor. Its normal.
 When I removed the camshaft to take away the decompressor, it seemed that the cog was a fixed part of the shaft, no nut there to be loctited - correct me if I'm wrong.
Referring to the one on the bottom not the cam gears
Also that phone is ancient
Edited by Gsxrstuntdrz
I see. I hope that doesn't mean another loctite fix ahead ?? Or will the counterbalancer and primary gear fixes take care of it ?
Edited by michaelks
If it is normal then what has worn to make that noise since its only been there for 3k miles? Normal for suzuki none of my hondas make those noises.
Referring to the one on the bottom not the cam gears Also that phone is ancient
Meet my cell :lol: .
I'm taking a break from my voyage to the DRZ innards, but next thing I'm pulling off the clutch-side cover to check on those two nuts, I can't trust the bike as long as I hear weird noises (mine's a knocking when under stress, people I've seen tell me it's normal),  this video really got me scared:
http://www.youtube.com/watch?v=YENOaYCn-Gk
guess I'll be pulling case this weekend thanks for the update.
i assume its the crank big end bearing. I put up vidoes of mine on youtube
sorry i wasn't clear enough. your other response was what i was referring to.
good luck
No "loctite-fix" on the stock camshaft.  The gear is pressed onto the stock camshaft, NO nut.
That's the counter-balancer nut (loose in the video).  The large nut to the left of that one, is the primary nut (crank snout).
Edited by bmwpowere36m3
