Oil leak
I was attempting a "simple" oil change today. Ha!
My frame sump plug got cross threaded/stuck and ended up rounding all the edges of the hex head.
So I took it in to my LBS.
He fixed it but I think (hope) he's removed the large nut & hose beside it whilst trying to remove it.
I say hope because there is now a leak from that nut. Here's a photo of it.
Photobucket Pictures, Images and Photos
So the questions are:
A) what is the nut attached to
B) can I retighten as it is or do I need to do a full drain and oil change.
It's a small leak - maybe 10mls or so in a few hours - but a leak that wasn't there before nevertheless.
Thanks?!
That's the nut is for the oil screen (secondary filter). It should be removed every few oil changes, cleaned and inspected. It's always a good idea to check the filter screen after break in and anytime you do motor work. It does appear to have a gasket though http://www.rockymountainatvmc.com/oem-schematic/2 I would verify that the gasket was installed and then attempt to snug up the nut.
Thanks for that. You're a legend.
It does look as though the gasket is under the nut.
I might take it back tomorrow and have them snug it up, though. I only have an adjustable wrench that fits and the last thing I want to do is stuff up another bolt.
http://www.thumpertalk.com/topic/576918-basic-oil-change-walk-through/?p=5539692
Thats the FAQ oil change walk through.. at the bottom of that article is a picture of the frame tank screen
Thanks Eddie. Yep, that's the part in question. I'm hoping it'll just need a half turn to snug it up.
It takes very little torque to get that fitting to seal..  If a very light snugging is not enough, the sealing washer may need to be replaced (or annealed), something deburred, ect
And Erik too
Sorry Mate, I knew it looked wrong when I typed but couldn't work out why. :confused:
