Help!
Pulled the carb...the float was stuck, I can't get the float out see picture below, red arrow is showing what is stuck in the carb, how do I go about getting it out??
I got it out.....carb is really dirty, ordering rebuild kit..... :cry:
Remove the hold down screw for the float.
Carefully, remove the float from the carb body, being mindful of the float tab and float needle valve wires.
If the float needle valve (your red arrow) is truly stuck the whole float needle valve assembly will need to be replaced.
I that case, remove the hold down screw for the needle valve seat.
Remove the needle valve assembly.
Replace with a fresh one.
Yup, I am putting all new back in as soon as the kit gets here :thumbsup:
Meanwhile I will try to clean it up real good.
I am having trouble to remove the float seat, any ideas?
Finally wiggled it free! Not a good day.....now to wait on kit.....ho hum
Hey, that's a good thing. It indicates that your o-ring on the seat was likely okay. My seat fell right out because the o-ring was shot. My bad o-ring, coupled with a leaky stock petcock, caused my bike to flood. :cry:
Yeah I don't know, it didn't look too good, but a new one coming in the kit. Yup, replaced a leaky petcock not too long ago!
