Whats that noise!?
So over the last month my road banana has developed an increasingly rattley engine.
Firstly, when it is cold the engine produces a loudish ticking noise.
Then when its warm the ticking disappears.
I have done the locktites, I have a mcct, the cam chain has been replaced not that long ago.
I will post bids of it warm and cold when I get home.
also I have noticed when just cruising along at lower rpms (not extremely low) the engine produces an audible knocking sound.
is it likely, at nearly 20000kms it needs to be rebuilt?
Thanks heaps fellas!
Here's the vids:
Cold - http://www.youtube.com/watch?v=3BmroRXiNTE
Warm - http://www.youtube.com/watch?v=1ArDHHBUhhs
Edited by YourPalsChrisAndAl
Mine didn't but I have heard of new cam chains stretching a little after installation….. Have you checked the MCCT since the chain was installed ?
Yeah I readjusted it when the ticking started.
Didnt help much.
Perhaps i should try again?
Btw, the videos are in my first post now
It says your videos are "private", dude.
have you removed the auto decomp?
sorry about that mate, fixed now!
No idea what this does or where it is. Care to elaborate? :D
Mine sounds like that all the time.....
the auto decomp is on your exhaust cam to make it easier to start.i believe and i have read somewhere on here it gets loud as its wearing out or worn out. from what i understand you can remove it with no ill affects.
Look at this : it's a guy with a brand-new DRZ who made a video of how it sounds for future reference - sounds just like yours (or even more noisy). I think unless there's some obvious abnormal alarming clunking or rattling, that's just how they are.
http://www.youtube.com/watch?v=4cdxtErPm6c
Edited by michaelks
I heard a ticking just like this from my bike, for the first time, on Tuesday. It was just before I was going out for a ride. I started suspecting the auto-decompressor or a valve, and almost didn't go because of it. When I got home, with a thoroughly warm motor, the ticking had stopped. I started the bike just a little while ago and there was no ticking.
+1 mine too...
not really sure about the ticking, but I believe its there...
Our pals , can you narrow down where the ticking is coming from ? In the cold vid you are below the motor , which would suggest the big end or balancer . ( If it is I would take off the side cover and have a look to see if one of the cogs have come loose ) But the warm vid is around the exhaust and above , which could be the auto decomp . greg
Checked your valve clearances lately...?
clearances will reduce marginally when engine heats up
BTW...you guys are a menace ...lol....http://www.youtube.com/watch?v=K028FeUWQnk
Edited by Craigo 485sm
I have a DRZ :ride:
I have No ticking , rattling , clunking
I have a DRZ :ride:
+1 on that...... ;)
Hey mate,
It is definitely in the top where the cams are...
Haven't checked the clearance... perhaps a good place to start :p
heh, you like that one?
Hey mate,
My ticking was in the front, around the exhaust cam, too. Mine seemed more evident on the left side. I even considered maybe I had a small exhaust leak at the pipe. When I checked my tappet clearances, a few months ago, both exhaust were on the tight side of spec.
i rode my bike to work this morning. No ticking. No problems.
LOOOL
After been riding with you Craig, I don't have to ask where Chris and Al learnt to ride on the footpath. :naughty:
