Is it common for KX250 to drip a couple drops of ATF after every ride?
Out of the vent tube under the bike.  Just one or two drops.
I always have it filled to the middle of the window or so.
Coo
Try measuring out your oil upon next refill. I've seen mine leak if bike tips over for a good while so yours may be too full.
Yes this happens in my bike too. I consider it normal as I've put hundreds of hours with no related issues
None of Mine leak .could Have been over filled . I run the belray 75 or 80w for my 02 kx 800cc works for me.
Probably from all that insane inverted air you insist on doing every time you think a girl is watching. You might try a longer vent tube routed up under the seat and back down.
Mine don't leak unless tipped over .
Ya, me too.
